• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2013/2014 DWG Format
    Active Member
    Publish Command
    167 Views, 5 Replies
    10-31-2012 02:42 AM
    Probably a silly question but after 2013 was installed in my colleagues computer he now has the option to include Layouts when opening the publishing command, which didn't happen before.  It is a slight pain removing these from the selection to be published and I was wondering how I get it to only select models and not layouts when opening the publish command as default.
    Please use plain text.
    pendean
    Re: Publish Command
    10-31-2012 05:11 AM in reply to: rabruce
    What version did you all use before 2013? Do you all save DSD (drawing sets) to reuse?
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    Active Member
    Re: Publish Command
    10-31-2012 05:32 AM in reply to: pendean
    As I mentioned it was a colleague who used it so I don't know about the .dsd file, but the version was 2012
    GrantsPirate
    Re: Publish Command
    10-31-2012 06:56 AM in reply to: rabruce
    Open publish, right click, uncheck Include ModelSpace, finish.  That should be set until it is changed manually by the user.
    pendean
    Re: Publish Command
    10-31-2012 07:44 AM in reply to: GrantsPirate
    ... I think they need to uncheck INCLUDE LAYOUTS WHEN ADDING SHEETS is I'm not mistaken.
    OP, it's done the same way in R2012: ask your user to document and save it.
    Active Member
    Re: Publish Command
    10-31-2012 08:05 AM in reply to: GrantsPirate
    I've spoken to my colleague and this has solved it.
    Thanks for all your help.
