• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Distinguished Contributor
    Possible bug with object angle field
    171 Views, 7 Replies
    07-28-2012 03:43 AM
    Draw a 20° sloped line.
    Add an object field to the line, the angle shown is 0.3491 and not 20
    Please use plain text.
    *Expert Elite*
    Re: Possible bug with object angle field
    07-28-2012 06:25 AM in reply to: Exmateria
    Not a bug. Angles are stored as Radians.  Use the additional format button and add the factor 180/pi  to convert to degrees.  Hint:  Use the system calculator and copy and paste the actual value into the factor field.
    07-28-2012 08:13 AM in reply to: dbroad
    This behavior was not the same in previous releases where angles were displayed in the current units. What happen if I open in AutoCAD 2013 an old drawing created in AutoCAD 2012? Is the angle in radians or converted to the currents units?
    *Expert Elite*
    07-28-2012 02:02 PM in reply to: Exmateria
    I retract my earlier statement.  It is a change and most certainly a bug.  You should report it via autodesk.com/submitbug
    07-28-2012 02:09 PM in reply to: dbroad
    Ok, i will do that.
    *Expert Elite*
    Patchy
    07-30-2012 07:42 AM in reply to: Exmateria
    Active Contributor
    AUGIfr
    07-30-2012 09:04 AM in reply to: Patchy
    Thanks, has a patch been posted?
    *Expert Elite*
    Patchy
    07-30-2012 09:11 AM in reply to: AUGIfr
