• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    *Expert Elite*
    Rave.Tam
    Opening file from Webfolder (Webdav)
    93 Views, 0 Replies
    01-14-2013 07:43 PM
    I have a sharepoint site which is configured to be accessible as a network folder. The problem is the performance. I monitor the network connection (using fiddler) between the server and my computer in autocad when using the open dialog box. For each folder that i click, it connect to the server and look up the folder hierarchy and run it for 4 times Consider i'm at 3 level deep, it will make 12 connction to the server. Average, it took about 8-9 seconds to navigate into a folder.
    On the other hand, if i use standard windows explorer, it only make 1 or 2 connection to the server, which is incredibly fast (less than a second).
    Does anyone know if there's any configuration in AutoCAD that can solve that?
    If my post answers your question, please click the "Accept as Solution" button.
    Check out my blog http://lazcad.com
    Please use plain text.
