• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Member
    No "copytolayer" in AutoCAD 2013?
    166 Views, 4 Replies
    11-21-2012 01:21 PM
    I was working in AutoCAD 2012 and just opened the drawing in version 2013.. The "copytolayer" does not exist as a command. It's weird because i searched online and it seems that it should be there. I have the educational version, but somehow i don't think that is the reason it's not showing up.
    Any ideas?
    Please use plain text.
    *Expert Elite*
    Re: No "copytolayer" in AutoCAD 2013?
    11-21-2012 01:50 PM in reply to: hmohar
    does it also not work if you start the command by typing it into the command-line?
    Out of the help it should work, and tried also on my 2013-version ==> it works!
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Member
    No, it doesn't exist, there is no icon for it, and it doe...
    11-21-2012 01:56 PM in reply to: alfred.neswadba
    No, it doesn't exist, there is no icon for it, and it doesn't work if typed in the command line.
    However, I found the solution here: http://forums.autodesk.com/t5/AutoCAD-for-Mac/copy-to-layer/td-p/2931712
    This is really wierd, becuse it seems to be working fine with most folks.
    Thank you anyway!
    *Expert Elite*
    Re: No, it doesn't exist, there is no icon for it, and it doe...
    11-21-2012 02:08 PM in reply to: hmohar
    Do you have AutoCAD on Mac?
    If so then I guess "working fine with most folks" is valid for the Windows-users.
    - alfred -
    Alfred NESWADBA
    Member
    11-21-2012 02:21 PM in reply to: alfred.neswadba
    Yes.
    This is it then. I can't beilive I never thought of this.
    I'm still mad, though :smileyhappy:
