• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Product Support
    Albert_Rius
    Re: No Thumbnail Preview in File Open Dialog Box - But Only for ONE User
    07-17-2012 08:35 AM in reply to: Bill.Schmid
    Hi Bill, Erika,
    Please can you check that the .DWG extension is correctly associated with AutoCAD?
    (just try to double click one of the DWG icons and verify that AutoCAD 2013 is started correctly)
    Also please can you check that if you open a file with AutoCAD, that the variable UPDATETHUMBNAIL is different to zero.
    Does the problem appears also if you save the file with previous releases? (saveas as 2010, 2007)
    ______________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Albert Rius
    Support Specialist
    Product Support
    Autodesk, Inc.
    Please use plain text.
    ErikaBruning
    07-20-2012 04:48 AM in reply to: Albert_Rius
    Albert -
    1) Yes, the .dwg is for AutoCAD.
    2) UPDATETHUMBNAIL was set to 15 (the same as what Bill is set at).
    3) THis is for all drawings, not matter what version they are saved as (2007 is our normal save as option).
    Erika
    Erika Bruning
    Windows 7 64-bit
    Autodesk Design Suite Premium 2013
    Active Member
    08-30-2012 08:44 AM in reply to: Bill.Schmid
    I have the same problem, I correct it using the repair function then export using Migrate custom settings.
    Every now and then it disappears again so I have to use the import the previously exported file. This corrects it until it happens again
    Active Member
    08-30-2012 10:23 AM in reply to: Bill.Schmid
    See attatchment for the open dialoge box after I use DXFIN command, Anyone know a easy way to get it back
    08-30-2012 10:45 AM in reply to: DennisJehan2969
    Dennis,
    I don't quite follow you.
    Repair: Would that be the repair function under the Windows Control Panel, Programs and Features, Uninstall/Change?
    Migrate / Export: Is that the Migrate Custom Settings program?
    Thanks!
    Bill Schmid
    Autodesk Product Design Suite Premium 2013
    Autodesk Vault Professional 2013
    Dell Precision T1650
    Windows 7 Professional SP1 64-bit
    Intel E3-1270 V2 3.5GHz / 16G RAM
    Nvidia Quadro 2000, Driver 276.42
    256 GB SSD
    Space Navigator, Driver Version 6.16.1
    Active Member
    08-30-2012 11:31 AM in reply to: Bill.Schmid
    Goto Start>All Programs > Autodesk > AutoCAD Mechanical 2013
    Select Reset settings to default
    Open AutoCAD and set-up as you like it, close.
    Then select Migrate Custom Settings and export to a Zip file
    Active Member
    08-30-2012 11:41 AM in reply to: Bill.Schmid
    To avoid loosing your preview in the open dialog box use Open>DXF from the open dialog instead of typing DXFIN
    ErikaBruning
    09-07-2012 10:34 AM in reply to: Albert_Rius
    This may or may not be a coincidence... Because of other issues we had here, I did a 'run as administrator' when re-installing DWG TrueView 2013. My previews show now.
    Erika Bruning
    Windows 7 64-bit
    New Member
    09-19-2012 06:44 AM in reply to: ErikaBruning
    i also have run the dxfin command and ran in to this issue as well.  we found that creating a new profile solved the issue without having to do any repairs or reinstalls.
    Distinguished Contributor
    jz4all
    11-14-2012 06:49 AM in reply to: Bill.Schmid
    Erika,
    See the attachment.
    Do you mean that in windows explorer, under views you don't have these choices?
    If you have them then you can choose (thumbnails), if not you can follow the solutions suggested by above contributors.
