• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    ADN Support Specialist
    Re: Need help with lisp routine.
    08-08-2012 02:41 AM in reply to: jeff.whitney
    Hi Jeff,
    No, I don't have that tool. I simply looked into the acad.lsp file that Patchy uploaded.
    Adam Nagy
    Developer Technical Services
    Autodesk Developer Network
    Please use plain text.
    *Expert Elite*
    Patchy
    08-08-2012 03:55 AM in reply to: jeff.whitney
    08-08-2012 04:00 AM in reply to: jeff.whitney
    Jeff - when we run the len command it brings up 4 options which we have to input.
    1) English or Metric
    2) Pipe Diameter
    3) Takeout in inches
    4) Text height
    Then we pick the endpoints of a line and it gives us the correct length that the pipe needs to be cut in the shop.
    Distinguished Contributor
    08-08-2012 07:43 AM in reply to: Patchy
    Thanks!
    08-13-2012 07:52 AM in reply to: adam.nagy
    I unzipped the content of lent.zip and then added the folder as the first Support File Search Path in Options, so that acad.lsp (that contains (c:len) definition) get loaded - tested in AutoCAD 2012
    Then I ran the len command and it seemed to work fine and the layer switched back after using it.
    I was thinking why it would not work for you and then I thought maybe you just use Esc to end the command, in which case the layer won't be switched back since the command execution gets interrupted and the layer switch back part won't be reached.
    Try to just simply press Enter/Space bar when you want to quit the len command.
    ______________________________________________________________
    If my post answers your question, please click the "Accept as Solution"
    button. This helps everyone find answers more quickly!
    Adam Nagy
    08-13-2012 08:26 AM in reply to: adam.nagy
    Ok, so this is one of theose "DUH" moments. Yes id did work. A fellow co-worker asked the question and I guess I should have tried that before posting. Thanks Adam.
