• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Product Support
    Re: Multileader not extending to text
    04-27-2012 07:13 AM in reply to: Vandeurzen
    Our developers were able to reproduce the issue and they are working on the matter.
    This does not seem to be OS related, so not a Vista conflict.
    Cheers,
    Luciane
    Please use plain text.
    Active Member
    04-27-2012 07:45 AM in reply to: mt1083
    I am running Windows XP SP3.
    Active Contributor
    04-27-2012 07:51 AM in reply to: luconceicao
    Yeah I figured it was probably not related. Thanks for starting the work on the fix though!
    Distinguished Contributor
    05-22-2012 06:43 PM in reply to: luconceicao
    Having IDENTICAL problem here with multileaders as to what has been explained in this post. Has anyone also noticed when selecting a grip on the text box (eg: the bottom left grip), it no longer aligns the cursor with the very front of the text box? There is a slight indent now of the cursor once the grip is selected.
    While we are working through fixes, have there been any reported problems with the Moroco tool? Had 3 fatal errors using this tool. Problem is intimitent though. I have sent reports to Autodesk.
    New Member
    06-27-2012 06:08 AM in reply to: mt1083
    I am having the same problem. We just switched to AutoCAD 2013 from 2012.
    Windows 7 Operating System
    Active Member
    arq002
    09-14-2012 04:40 AM in reply to: Vandeurzen
    Has a patch for this been available yet? I have the same problem, just a little different.
    See attached.
    Product Support
    10-04-2012 07:36 AM in reply to: arq002
    Have you already installed the service pack 1.1?
    AutoCAD 2013 SP 1.1: http://usa.autodesk.com/getdoc/id=DL20327837
    Cheers,
    Luciane
    Active Contributor
    10-04-2012 08:00 AM in reply to: luconceicao
    I just installed the service pack and that seems to have fixed the issue. Thanks!
