• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Member
    Multi-Line Text Imaginary Box
    128 Views, 4 Replies
    10-12-2012 08:16 AM
    we have several columns of multiline text and draw a line to the left of each column.  problem is when the text increases or decreases the number of rows the line does not change.  is there a way to have this line dynamically change as the number of rows change?  or is there a way to snap a line on the imaginary box around the text?
    Please use plain text.
    *Pro
    Re: Multi-Line Text Imaginary Box
    10-12-2012 09:49 AM in reply to: FinleyPower
    Three options...
    1. If you know how to use drawing constraints, can assign the endpoint of the line to the "node" of the MText (one corner of MText has it's insertion point, and the other three corners are the nodes) so that when you add or remove text, the constrained line will adjust automatucally
    2. If you don't want to get into constraints, you can simply click on both the MText and Line, and then simply grab the end-point grip of the line, and the drag and click on the node of the MText
    3. If drawing the line for the first time, you can use the osnaps INS [INSertion] and NOD [NODe] to snap to the MText object
    Member
    10-12-2012 10:11 AM in reply to: murray-clack
    I'll study constraints. Can you tell me which type to use? thanks
    Member
    10-12-2012 11:32 AM in reply to: murray-clack
    tried several constraints and not successful???
    *Expert Elite*
    pendean
    10-12-2012 01:37 PM in reply to: FinleyPower
    Single-Cell table: has it's limitations, see attached, which can be overcome manually though.
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
