• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Active Member
    Mouse wheel click snap menu?
    929 Views, 9 Replies
    08-23-2012 09:08 AM
    When zooming, I middle click the mouse to bring up osnaps, then type the letter to force the snap I want.  That stopped working today: the menu pops up, I type "E", the menu goes away, but it doesn't default to endpoint, there's an "E" on my command line.  Any ideas?
    I'm not sure if this is a Service Pack 1 issue or not, but I just installed that yesterday.
    Thanks!
    Please use plain text.
    pendean
    Re: Mouse wheel click snap menu?
    08-23-2012 09:36 AM in reply to: CADragon
    Did you change the mouse driver setting for the middle button?
    or edit the mouse button setting in CUI command?
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    08-23-2012 09:44 AM in reply to: CADragon
    This post has someone with the same issues as us: http://forums.autodesk.com/t5/AutoCAD-2013/SP-1-Is-Available/td-p/3590872
    For me, it is when I shift+ right click and hit a hot key.  Funny thing is it only works the first time, every other time it just redirects the key into the command line after closing the menu.  Excel menu hot keys still work fine so it's not a system issue.  I did toggle underlining hot keys in the control panel, and verified the & key is still present in the CUI also.
    Active Member
    08-23-2012 09:44 AM in reply to: pendean
    I haven't done either of those that I can think of.  Is there a setting you can think of offhand that I could modify in the CUI?
    Active Member
    08-23-2012 09:47 AM in reply to: robertstroz8845
    Thanks, I did a search, but I couldn't find anything.  Good to know it's not just me.  I knew I shouldn't have applied the SP taht fast, I usually wait a month or two.  That'll teach me!
    pendean
    08-23-2012 12:57 PM in reply to: CADragon
    So it broke only after SP1 was installed?
    Active Member
    08-23-2012 01:07 PM in reply to: pendean
    Yes, that's when I noticed it.  Check the link above that Robert provided, other people are having it, too.
    pendean
    08-23-2012 01:25 PM in reply to: CADragon
    Well, they have withdrawn it so maybe they will fix it again. You're looking at a removal and reinstall of 2013 for now.
    09-12-2012 09:19 AM in reply to: pendean
    Looks like the latest SP1.1 for x64 win7 has fixed this issue; although, I did not notice it mentioned within the readme.
    Rob.
    Distinguished Contributor
    09-12-2012 11:58 AM in reply to: CADragon
    I haven't tried SP1.1 yet (I figured I'd give them a few days to see if they tell us it has fatal flaws first), but I was one of those who installed SP1 when it came out and it did in fact screw up the o-snap shortcuts just as you mentioned. Uninstall SP1 through control panel and it will start working correctly again.
