• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Maintain customized layer state.
    253 Views, 5 Replies
    11-05-2012 06:53 AM
    Hey,
    Im having a layer state issue with ACADE 2013; its a generic layer problem that's why I'm posting on the ACAD forum.
    Vive saved a Layer state ("trial state") that has about 30 layers and some of them have been frozen.
    I made the trial state the current layer state, however, when I save and close the drawing and then reopen it, "Trial State" is no longer the current state. Instead the layer state is changed to "Unsaved Layer state", and I have to manually select my trial state each time. I haven't even modified any layers or added more layers and it does this.
    Im wondering if there is any way to keep/lock my customized layer state on a drawing.
    I've added some pictures to help out.
    Thanks for the help,
    James Bunch
    Please use plain text.
    pendean
    Re: Maintain customized layer state.
    11-05-2012 08:00 AM in reply to: jbunch55
    You seem to be describing the function of layer FILTERS but using layers States instead.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    11-05-2012 10:30 AM in reply to: pendean
    I've never used Filter Layers so maybe I don't understand them completely, but I don't think that's what I want.
    I'm trying to make a temp project for autoCAD electrical, so I'm adding as many layers as possible to the the temp dwgs.
    I need to modify those layers so that certain attributes (e.g.. child_xref) don't show up on the schematic.
    I figure the Layer State manager is the way to go, because I can save an .las with all the layers and import it to each temp drawing. The problem is that the drawings don't stay on the customized layer state that I make.
    Maybe I should post this in the ACADE forum.
    Thanks for the idea though.
    James Bunch
    HAMJAM
    Retaining layer state manager settings
    11-19-2012 10:19 AM in reply to: jbunch55
    James
    I have had exactly the same issue and it is very frustrating.
    The only work around I can find is get the drawing with all the layers in the desire state and name the state in your case "Trail State".  Before you exit the drawing export the layer state settings - it will be a ".las" file.
    When you reopen the drawing and find all your layers messed up import the layer state "Trail State.las" settings and your drawing will return to the desired state.
    If anybobdy has a better way of retaining a layer state (there must be one) I would love to hear.
    Kind regards.
    Re: Retaining layer state manager settings
    11-21-2012 12:38 PM in reply to: HAMJAM
    That work around doesnt work too well for me.
    I've posted in the ACADE 2013 forum and hopfully that will get an answer.
    James
    HAMJAM
    11-21-2012 01:09 PM in reply to: jbunch55
    Fully understand that this is not a great work around.
    I look forward to hearing if anybody else has a better solution.
    Kind regards
