• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2013/2014 DWG Format
    Member
    Link two points
    112 Views, 5 Replies
    07-23-2012 07:59 PM
    There are to points and between them a lot of obtructions therefore there is not possible to link using only ome line. Is there a command to link ?
    Please use plain text.
    Re: Link two points
    07-23-2012 09:26 PM in reply to: construccion777
    PLINE command
    AutoCAD Map 3D 2013
    Windows Vista Business
    Service Pack 2
    Intel(R) Core(tm2) Quad 3.0 GHz
    4.0 GB RAM
    Member
    Re: Link two points
    07-24-2012 07:42 AM in reply to: construccion777
    Yes but you have to define the path . I am looking for an automatic method . This is very usefull to design circuits.
    Re: Link two points
    07-24-2012 08:30 AM in reply to: construccion777
    You'd have to investigate available verticals or third party apps..  Automatic routing is not available in Autocad base.
    Re: Link two points
    07-24-2012 11:26 AM in reply to: construccion777
    Are you familiar with parametric geometry constraints?
    Post an example file here.
    Might be as simple as coincident constraint.
    Inventor Professional 2014 Edu 64-bit
    Member
    Re: Link two points
    07-24-2012 12:30 PM in reply to: construccion777
    Thank you I will check the example
