AutoCAD 2013/2014 DWG Format
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Leaders in dynamic blocks
- Highlight
- Email to a Friend
- Report Inappropriate Content
I created a dynamic block that contains a quick leader. The problem I have is when I go to my layout views the leader in the block does not show up. If I edit the block, change the layer of the leader and save it then the leader will show up in viewports. Other parts of the block are on the same layer and show up, it is just the leader for some reason. Any ideas? Has anyone else had this experience?
Re: Leaders in dynamic blocks
- Highlight
- Email to a Friend
What layer does the leader start out on, and then what layer do you change it to when it shows up? Are the block and the layer in the same drawing, or is it an xref? Are you using annotative scales? This will give us a much clearer picture of what may be happening.
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
Does it show up when you print? Here in our office, there are some blocks, text, etc. that don't show up on the screen, but they show up fine in the print preview or when we print them (even to a pdf).
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
Can you post the block or a sample drawing so that we can take a look at it?
Cheers!
Volker
Volker Cocco
Support Specialist
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
Here is the block...
- Highlight
- Email to a Friend
I made a copy of the annotative dimension style which was applied to the leader. The new style is non-annotative. The original annotative style had a 1:1 annotative scale assigned to it. Since the leader was nested in the block it would not update when you applied new annotation scales. It worked fine for me, please test it and let me know.
Cheers!
Volker
Volker Cocco
Support Specialist
Product Support
Autodesk, Inc.
