• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2013/2014 DWG Format
    Valued Contributor
    Leaders and Block Data
    79 Views, 1 Replies
    01-23-2013 07:58 AM
    Morning -
    I am trying to create a leader that reads the block "name" and then places it into circle, or square at the end of a leader.
    I see it in the "other" programs but I have plain ole Autocad.
    Should be simple enought except my brain is locked in the clouds and im spinning around in circles.
    Which may not be a bad thing, except NASCAR hasnt  started yet
    Can somebody point me general direction on how to get this accomplished
    thanks
    Please use plain text.
    *Expert Elite*
    Re: Leaders and Block Data
    01-23-2013 08:29 AM in reply to: XlhHarley
    You can add an object field and put a rectangle and leader to it.  In order to have the field, a leader, and an enclosing object in AutoCAD, you would need to create a custom command.
    AutoCAD Architecture (and other verticals) has this tagging feature built-in.
