• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Member
    ZangerlT
    Layout Quality Problem
    409 Views, 7 Replies
    11-06-2012 07:41 AM
    Hello
    I have a problem with creating views from a 3D Model.
    When I'm setting up a View with "Create View/Base" all works fine. But when i change the shading to "hidden Lines" the quality of the shading is very very poor and not useable.
    Can anybody tell me if there is a setting for this?
    Thank you
    Thomas
    (Sorry for my translation and englisch)
    Please use plain text.
    Re: Layout Quality Problem
    11-06-2012 08:19 AM in reply to: ZangerlT
    what happens if you change it to Legacy-Hidden (in the property window while having selected the viewport).
    - alfred -
    Alfred NESWADBA
    Member
    ZangerlT
    11-06-2012 10:41 PM in reply to: ZangerlT
    Sorry i have the German version of Autocad... Is Legacy-Hidden the option shown in Pic1?
    If this is what you mean, it doesn't matter if i choose one of the two bottom options, it's always the same.
    Pic2 shows the property-window of a viewport...
    Member
    ZangerlT
    11-07-2012 06:59 AM in reply to: ZangerlT
    Has nobody a solution for this problem?
    Member
    ZangerlT
    11-07-2012 11:48 PM in reply to: ZangerlT
    Really nobody has this problem or a solution for this?
    11-10-2012 12:35 PM in reply to: ZangerlT
    sorry first, it was not clear to me that you spoke about command _VIEWBASE and objects of type "drawing view" (Zeichnungsansicht), I thought that were simple (shaded/hidden) viewports.
    If you look to your screenshot while you have selected one of that drawing view objects you see the property "Shade resolution" (Schattierungsauflösung) is set to 100dpi (what's quite low).
    The chance you have is to first set the shading resolution to 300dpi (>>>details English<<<  >>>details German<<<) and then start the _VIEWBASE command to place your views. Sorry, I didn't find a way to change the resolution afterwards.
    - alfred -
    Alfred NESWADBA
    Member
    ZangerlT
    11-11-2012 10:44 PM in reply to: ZangerlT
    Hi
    Thanks for your reply. In the meanwhile I've found out how to set the resulution higher, but as you see in the new screenshot, it doesn't change anything about the quality...
    Product Support
    Mlgolf
    11-19-2012 06:13 AM in reply to: ZangerlT
    Hi ZangerlT,
    The described behaviour has been reported to our division and a note added to include this case.
    Kind Regards,
    Martin Langolf
    Product Support Specialist
