This problem just started when I upgraded to 2014. When I try to set up layer filters the Layer filters properties dialog box does not show. I'm guessing the function is working its is just that the dialog box is poping up somewhere out of view of the monitors, forgot to mention it is a 2 monitor set up. Suggestions anyone?
Solved by 27thofnever. Go to Solution.
ALT + SPACEBAR, then M, then arrow keys left or right. If it is truly off screen, it will come floating back.
Help!!!
I'v lost my layers dialog box and I don't quite understand this past answer. Does ALT + SPACEBAR mean that I hold them both down while I am hitting the arrow key, ALT then SPACEBAR then ARROW KEYS.
I've tried them both and can't get the dialog box to show up. I am running two moniters an AutoCAD 2015.
Is there a command to get all boxes to come back to one location?
If I remember correctly I pressed ALT + SPACEBAR, then M, while holding those keys down then arrow keys left or right.
Thanks David but it doesn't work for me.
I can't even tell if the Layer Properties Manager box is open somewhere that I can't see it. I type in the command LAYERS and get nothing.
Does anyone have any ideas?
