• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    New Member
    Joining Polylines, without changing dimensions
    223 Views, 4 Replies
    02-11-2013 10:51 AM
    Hi, I'm having a bit of trouble getting my polygon closed without changing the dimensions of the polygon.
    The drawing attached or at http://img13.imageshack.us/img13/7494/drawingz.png you can see I've got a polygon.
    However I do not know the radius of the angles A, B and C. I know that all the lines have to be the dimensions marked.
    Can Autocad automatically bend the angle say, at A without changing the dimensions in order to complete the polygon? I tried this http://forums.augi.com/showthread.php?106618-Joining-polylines but found it wasn't what I wanted.
    Please use plain text.
    Re: Joining Polylines, without changing dimensions
    02-11-2013 12:16 PM in reply to: jonestim324
    Use Constraints and Parametric dimensions (see the Parameters tab).
    see attached - drag the endpoint - is this what you want to do?
    Add parametric angle dimensions for the angles you know.
    Active Contributor
    LaserGuy
    02-12-2013 05:08 AM in reply to: JDMather
    Dell T7500
    x5690 Xeon 3.46/3.73GHz
    24Gb, SSDs, Quadro, Win7 x64
    AutoCAD Mechanical 2014
    New Member
    02-12-2013 07:26 AM in reply to: jonestim324
    Thankyou very much for the reply, I was able to reproduce this in my copy of AutoCad 2013 for MacOSX.
    I see that for d1 3500 I see you set:
      * Parametric > Dimensional Constraint > Horizontal
      * Parametric > Geometric Constraints > Fix
    For second line, d2 2320 I see you set:
      * Parametric > Dimensional Constraint > Vertical
    For d3, d4, and d5 it appears that you set:
      * Parametric > Dimensional Constraint > Aligned
    I also noticed the constraint between d2 & d3, d3 & d4, d4 & d5 you set:
      * Parametric > Geometric Constraints > Coincident
    However I realized that there's multiple pentagon shapes which have the same amount sides (5) with the same dimensions but different angles (other than the 90 degree angle). I must have been a bit tired when I asked this question, because that didn't occur to me, heh.
    Constraining them only takes care of the lengths, I really need to take some measurements from my physical application.
    I had the same error as LaserGuy mentioned there, but it seemed to be fixed when I added the coincident constraints and clicked on on the line rather than the endpoints. (At least that's what I think I did).
    In this thread http://forums.augi.com/showthread.php?146224-Joining-Polylines-without-changing-lengths-unknown-ange... people suggested using the midpoint and endpoints with intersecting circles in order to work it out, however I don't think this will be necessarily the right angles for my real world application.
    Thanks for the helpful answers to an Autocad newbie :smileyhappy:
    Active Contributor
    LaserGuy
    02-12-2013 07:36 AM in reply to: jonestim324
    My example was to show that you need to remove at least two of the contraints to close the geometry.
    Dell T7500
