• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Distinguished Contributor
    Install error AutoCAD 2013
    2054 Views, 3 Replies
    10-04-2012 01:56 PM
    I get an installation error when installing 2013.
    AutoCAD installs fine but it is the inventor component that hass an error.
    I believe this is due to me having a newer version of Microsoft Visual C++, i require this for other software.
    Does anyone have any suggestions, it wouldn't normally bother me but i get an annoying message telling me that AutoCAD hasn't been installed properly every time i start up.
    The error is below:
    2012/10/5:09:35:39 Geg GEG-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): D:\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Geg\AppData\Local\Temp\vcredist_x86_2005.log"" "
    2012/10/5:09:35:46 Geg GEG-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
    Creative Intentions
    Win 7 Pro 64bit, Dell Precision M6500
    Please use plain text.
    Re: Install error AutoCAD 2013
    10-05-2012 10:57 PM in reply to: GegH1
    I had a similar problem some time ago when Windows-update had updated the C++XXXX redistributable to a newer version than DesignReview (as part of the AutoCAD-installation) tried to install.
    The solution was to uninstall the C++xxxx redistributables (including updates if there are any) and then start the installation again.
    Good luck, - alfred -
    Alfred NESWADBA
    10-06-2012 01:32 AM in reply to: alfred.neswadba
    The problem is i need c++ because i am building an application with visual studio.
    Creative Intentions
    10-06-2012 04:06 AM in reply to: GegH1
    You should just uninstall the redistributable! And when AutoCAD installed then successfully you can reinstall it again (if it's not already installed then by AutoCAD).
    - alfred -
    Alfred NESWADBA
