AutoCAD 2013/2014 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Importing Solidworks .SLDPRT and .SLDASM Files
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have read that one of the new features of AutoCAD 2013 is the ability to import Solidworks .SLDPRT and .SLDASM files through AutoCAD's Content Explorer, or through the Insert>Import command. Trying out this new capability (both methods of importing tried), I find that AutoCAD recognizes the file exension, and quickly goes though the command without any errors, but fails to import anything.
Anyone else experiencing this?
Windows 7 Professional, Service Pack 1
Intel Core i7 CPU
16.0 GB
64-bit Operating System
NVIDIA Quadro FX 1800
Re: Importing Solidworks .SLDPRT and .SLDASM Files
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
At the end of the tranlate do you see a message at the bottom saying "Import File Processing Complete - The translated file is ready to be imported"?
Have you been selecting that file in the message?
inventor :-)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Check lower right corner of screen (at least that was the way it was in 2012 - I haven't seen 2013 yet).
There should be a help file somewhere on importing.
As indicated - it doesn't pop onto your screen as you might expect. There is an additional step to import after the translation is complete.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have another question...![]()
After you have imported a 3D file from another application (eg, Solidworks) into AutoCAD, is the any way you can update that part in AutoCAD if it gets changed/edited in Solidworks?
When you attach external files as xref's, you can update them when they change. Is there any way to update/reload imports????
inventor :-)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
With some experimeting I've found a way to update the 3D model imported into AutoCAD from another application such as Solidworks (i.e. if they have been further modified in the other application).
When using the "Import" command the imported 3D model becomes a block, it now has a block name.
While that drawing is open create a new drawing.
In that new drawing Import the the "solidworks" model again (which has been updated).
Go back to your original drawing.
Use the "Viewcenter' command to update that block.
On the "Viewcenter" dialog box select open drawings and choose that new drawing (you can choose it even though that new drawing hasn't been saved).
Update the block in your current drawing with the new block from that new drawing.
Close that new drawing without saving it.
Could some smart programmer please write a macro to do the above steps with one click.
Then we would be working with live models in AutoCAD and if they are chaged in the other application (eg Solidworks), the changes can be updated in the AutoCAD model. ![]()
inventor :-)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Not seeing anything pop up on the screen; no balloon, no prompt at all.
The command prompt just shows the name of the Solidworks file; nothing to select at that point.
Intel Core i7 CPU
16.0 GB
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
OK - I'm getting the impression that I'm running into this difficulty because of the platform I am using.
I didn't mention this before, but I'm running Civil 3D 2013, but running as plain AutoCAD 2013.
Maybe Autodesk doesn't make importing of Solidworks into Civil 3D version?
That would be unfortunate, if that is the case.
Intel Core i7 CPU
16.0 GB
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes, Civil3D and AutoCAD does have different import-functionality (Civil3D more limited).
The easiest way to verify that is to start command _IMPORT and within the file-selection dialog check the file-types that the dialog has built in.
- alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It does list both .SLDPRT and .SLDASM files, and those types are selected as the default.
I thought this might be a simple fix, but I think I'll send in a support request to Autodesk and see what they say.
Thanks, all for your help! ![]()
Intel Core i7 CPU
16.0 GB
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Same problem here with vanilla 2012. I see the imported file in the block list. I get grips when use qselect to pick it. Start the block editor and open the block and do a Ctrl+A and select all finds nothing.
Inventor Fusion 2012 has the same problem, it works on opening the part but it turns out to be an empty file.
And it is a simple SW part.
