• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Member
    Image Shifting in Paper Space
    335 Views, 4 Replies
    04-12-2012 12:59 PM
    I am having an issue with my designs not lining up with my background aerial images when I zoom in and out in paper space.
    Everying remains lined up in model space, it is just paper space where I have the issues.
    This is only an issue when I use the dview comand and have twisted my drawings.  Does anyone have a suggestion?
    Please use plain text.
    *Expert Elite*
    Re: Image Shifting in Paper Space
    04-12-2012 01:27 PM in reply to: jchazard
    do you have the problem now with AutoCAD 2013 or with >>>2011<<< ? Or both?
    What graphic card do you have?
    have you activated or deactivated the hardware-acceleration?
    Can you give some info about hardware and software you are using?
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Valued Contributor
    04-13-2012 12:43 PM in reply to: jchazard
    One suggestion:
    Make certain you didn't inadvertantly shift your Z-axis. When your Z-axis is off fractionally, items can appear to be shifted. The DVIEW Points, Target, and Points options are all prime candidates for an accidental Z-axis shift.
    Mike Partenheimer
    Member
    04-16-2012 04:59 AM in reply to: jchazard
    Hey the problem is with AutoCAD 2013 ... but has also happend to others with older versions of AutoCAD in the office
    The computer has a 1024 MB graphic card   - 7.1 / 8
    AMD Radeon HD 6600 Series
    we are currently looking into the hardware acceleration
    10-31-2012 06:17 PM in reply to: jchazard
    I have been having same problem for over 3 years now.
    Civl3d 2009.
    I thought it was fixed by using VIEW command in viewport (type VIEW in command line while in model space of viewport), toggle perspective on (scary image), toggle off. Image seemed to stay put.
    This is not working anymore.
    I now put a bold disclaimer on all drawings....."image shifted due to inherent failures of Autodesk products and the company's inability to address software problems"
    not really...but it is frustrating that this glitch is not addressed properly and has been posted several times in discussion forums.
