AutoCAD 2013/2014 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: I Hate Setting Up New Versions and Losing more Hair!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
>> Any ideas why this is happening?
If so, we would also have a solution ![]()
I would really check the other (new) user-account as then the CUIX file used does not include the modifications you did.
If you can save all your customization-modifications you can also try to reset your settings of AutoCAD by using the profile-reset-option in the Windows-Start menu (section Autodesk ==> AutoCAD 2013).
- alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
What command/macro are you asigning to the dimesion?
^C^C_ddedit or ^C^C_TEXTEDIT should work.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It appears it has someting to do with Civils 3D. I have just run civils as AutoCAD and all works fine, plus a couple of other things that don't in civils.
Well I've got a technical support in with AD so I'll just wait to see what they offer.
Ta
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I've now tried in Civil3D 2013 (German) and for me the double-click works also fine.
That is one way of my statement previously "try it with anohter profile". So again: try it with another user-account, maybe you have then the double-click working and can transfer the settings from the other user-account to yours.
- alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Tried another user account, same problem.
Looks like its a Civils problem.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
In the future, if you'll mention it's Civil 3D at the start, or post in the Civil 3D forum, you might get a quicker solution.
In my Civil 3D 2013 as AutoCAD, there is a double-click action for dimensions.
In Civil 3D 2013 (not as AutoCAD), there is NOT a double-click action.
So I added one for Civil 3D, and it works now.
Can you try this?
R.K. McSwain
CADpanacea.com | twitter | Cadalyst Tips
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Done all of that before I even posted here and no joy.
In my experience generally these types of bugs effect all variants of AC.
I only mentioned Civils after I came to the conclusion it was possible a civils problem. If I mention civils to start with, people not using it wouldn't generally be interested.
Still, it's interesting that you can get it to work in civils and I can't!
Hey ho. My hunt goes on.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Are you 100% positive that you set it up right? Because I have the same situation here, and mine is working now.
I made a mistake the first time and it didn't work, and I had to go back and double-check my edits and correct something.
Don't get me wrong, I'm not saying you don't know what you're doing.... but two stock installs of Civil 3D should operate the same way.
R.K. McSwain
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yep all sorted thanks.
I think my original effort had a mix up of command names and types. I deleted and started again rather than modifying now it works!
as a side, have you managed to get the Contextual Ribbonfor array working as civils was not original configured with the new Array tools?
Cheers
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Cheers
Good deal.
What I found was that the ACAD menugroup in "Civil 3D as AutoCAD" contains the Array Contextual tab/state/etc.
The ACAD menugroup (partial menu) in "Civil 3D" is actually the AutoCAD Map menu (map.cuix) and does not contain this stuff....
I suppose you could transfer the necessary tab/state/etc. from the "acad.cuix" to the "map.cuix" or a custom menu - but I have not tried this.
R.K. McSwain
