• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    New Member
    How to turn off Save List As Dialog when publishing drawing?
    199 Views, 2 Replies
    04-18-2012 02:52 AM
    Does anyone know how/which system variable to change such that the Save List As dialog box don't appear every time I click on the publish button?
    Thanks!
    Please use plain text.
    Product Support
    Re: How to turn off Save List As Dialog when publishing drawing?
    04-20-2012 02:32 AM in reply to: beeonn
    if you check the "Always perform my current choice" option and click on "No", the "Save Sheet List" prompt will not be presented to you anymore.
    If you want to re-enable it, you can do this in the AutoCAD Options on the System tab. Click on "Hidden Messages Settings" and add a check next to "Publish".
    Hope this helps! :smileyhappy:
    Best regards,
    Silvia
    Silvia Menon
    Support Specialist
    Product Support
    http://www.autodesk.com/autocad-support
    ________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This will help everyone find answers more quickly.
    New Member
    04-22-2012 06:28 PM in reply to: Simenon
    Yes, I accidentally clicked on the wrong button when prompt the save list prompt :smileyfrustrated:
    I did thought that maybe I could turn it back on in the Options, but I keep looking under the Plot & Publish Tab instead of System Tab.
    Problem solved!
    Thank you! :smileyvery-happy:
