• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    New Member
    Accepted Solution
    How to install Autodesk Autocad 2013 x64 or x86 on Windows 8 Consumer Preview?
    16087 Views, 4 Replies
    04-03-2012 05:25 AM
    The Autocad 2013 x86 or x64 is not installed on Windows 8 Consumer Preview
    because programs can not read .NET Framework versions 2 and 4 which are integral parts of the OS. How do you solve this problem?
    Please use plain text.
    *Expert Elite*
    rkmcswain
    Re: How to install Autodesk Autocad 2013 x64 or x86 on Windows 8 Consumer Previe
    04-03-2012 05:41 AM in reply to: m.agert
    Windows 8 is not a supported O/S
    *Expert Elite*
    pendean
    04-03-2012 05:45 AM in reply to: m.agert
    Long thread with good information:
    http://forums.autodesk.com/t5/CAD-Managers/Anyone-try-Windows-8-Developer-preview/td-p/3349977
    Basically, since Win8 aleady has .NET4 you need to manually edit the installer to not try and install it.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Active Member
    05-30-2012 12:04 AM in reply to: pendean
    installation of autocad 2013 worked fine by editing the .ini file, but it crashes with unhandled access violation error!! :smileysad:
    check this out:
    http://forums.autodesk.com/t5/AutoCAD-Mechanical/AutoCAD-and-Windows-8-Consumer-Preview/m-p/3430011
    New Member
    11-20-2012 01:22 PM in reply to: m.agert
    ive just got autocad 2013 to run in windows 8....took 5 minutes....
    1.  right click desktop icon and set compatibility mode to windows 7
    2. Swipe in from the right edge of the screen, and then tap Search.
    3. (If you're using a mouse, point to the upper-right corner of the screen, move the mouse pointer down, and then click Search.)
    4. Enter Windows features in the search box, tap or click Settings, and then tap or click Turn Windows features on or off. You might be asked for an admin password or to confirm your choice.
    5. turn on all features for netframework 3.5, and for 4.5
    bingo.....somehow it now works !!!!
    i dont understand any of the voodoo that makes windows work....but i do remember having to install net framework on previous versions of windows, so i guessed it was importatnt.... i found out its all there ready to go in windows 8, but its just switched off.
