AutoCAD 2013/2014 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
How to fill up color in polygons?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have a drawing (.dwg) file. It is having so many polygons created by polyline. I want to fill up those polygons by a color. How can I do the same in AutoCAD?
After that How can I generate .svg from .dwg?
Re: How to fill up color in polygons?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hatch with solid.
Attach your example drawing here, let's see.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Sorry for late response,
I am not getting required result using hatch tool.
Actually I have so many polygons in a drawing (.dwg) file. Using hatch file, I am able to select only one ploygon at a time. I need a script which can hatched all objects at a time.
Can we apply hatch tool on all layers simultaneously?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
No, HATCH command requires some sort of selection of objects or spaces: you can explore using QSELECT or FILTER or SELECTSIMILAR commands to create such selections based on whatever criteria they all share in common.
AFAIK you can select more than one at the same time, you just need to be aware of your hatch "island detection" settings of these objects overlap. Also look up and set HPSEPARATE variable to what you need.
