AutoCAD 2013/2014 DWG Format
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
How to export to pdf
- Highlight
- Email to a Friend
I need to export this project to a PDF but it is not letting me. It keeps on say error.
Re: How to export to pdf
- Highlight
- Email to a Friend
I get no error at my end, appart from it being an educational version. Ensure the DWG to PDF.pc3 file is for the current version of AutoCAD, and not pointing to an old version of this file.
KarelCAD Application Support Specialist
- Highlight
- Email to a Friend
it still saying error. I double check every thing.
- Highlight
- Email to a Friend
this is what it says:
| Job: - Error(s) Did Not Plot
Job ID: 11 Sheet set name: Date and time started: 12/5/12 Wednesday, December 5, 2012 3:18:02 PM Pacific Standard Time Date and time completed: 12/5/12 Wednesday, December 5, 2012 3:18:03 PM Pacific Standard Time UserID: Peanut Profile ID: Total sheets: 1 Sheets plotted: 0 Number of errors: 3 Number of warnings: 0
Job ID: 10 Sheet set name: Date and time started: 12/5/12 Wednesday, December 5, 2012 3:17:49 PM Pacific Standard Time Date and time completed: 12/5/12 Wednesday, December 5, 2012 3:17:50 PM Pacific Standard Time UserID: Peanut Profile ID: Total sheets: 1 Sheets plotted: 0 Number of errors: 3 Number of warnings: 0
Job ID: 9 Sheet set name: Date and time started: 12/5/12 Wednesday, December 5, 2012 3:17:25 PM Pacific Standard Time Date and time completed: 12/5/12 Wednesday, December 5, 2012 3:17:26 PM Pacific Standard Time UserID: Peanut Profile ID: Total sheets: 1 Sheets plotted: 0 Number of errors: 3 Number of warnings: 0
Job ID: 8 Sheet set name: Date and time started: 12/5/12 Wednesday, December 5, 2012 3:13:58 PM Pacific Standard Time Date and time completed: 12/5/12 Wednesday, December 5, 2012 3:13:59 PM Pacific Standard Time UserID: Peanut Profile ID: Total sheets: 1 Sheets plotted: 0 Number of errors: 3 Number of warnings: 0
Job ID: 7 Sheet set name: Date and time started: 12/5/12 Wednesday, December 5, 2012 3:13:10 PM Pacific Standard Time Date and time completed: 12/5/12 Wednesday, December 5, 2012 3:13:11 PM Pacific Standard Time UserID: Peanut Profile ID: Total sheets: 1 Sheets plotted: 0 Number of errors: 3 Number of warnings: 0
Job ID: 6 Sheet set name: Date and time started: 12/5/12 Wednesday, December 5, 2012 3:10:15 PM Pacific Standard Time Date and time completed: 12/5/12 Wednesday, December 5, 2012 3:10:16 PM Pacific Standard Time UserID: Peanut Profile ID: Total sheets: 1 Sheets plotted: 0 Number of errors: 3 Number of warnings: 0
Job ID: 4 Sheet set name: Date and time started: 12/5/12 Wednesday, December 5, 2012 3:09:10 PM Pacific Standard Time Date and time completed: 12/5/12 Wednesday, December 5, 2012 3:09:10 PM Pacific Standard Time UserID: Peanut Profile ID: Total sheets: 1 Sheets plotted: 0 Number of errors: 3 Number of warnings: 0
Job ID: 3 Sheet set name: Date and time started: 12/5/12 Wednesday, December 5, 2012 3:07:57 PM Pacific Standard Time Date and time completed: 12/5/12 Wednesday, December 5, 2012 3:07:58 PM Pacific Standard Time UserID: Peanut Profile ID: Total sheets: 1 Sheets plotted: 0 Number of errors: 3 Number of warnings: 0
| Job: - Plotted with Errors(s)
Job ID: 2 Sheet set name: Date and time started: 12/5/12 Wednesday, December 5, 2012 3:06:20 PM Pacific Standard Time Date and time completed: 12/5/12 Wednesday, December 5, 2012 3:06:23 PM Pacific Standard Time UserID: Peanut Profile ID: Total sheets: 2 Sheets plotted: 1 Number of errors: 3 Number of warnings: 0
Job ID: 1 Sheet set name: Date and time started: 12/5/12 Wednesday, December 5, 2012 3:05:43 PM Pacific Standard Time Date and time completed: 12/5/12 Wednesday, December 5, 2012 3:05:46 PM Pacific Standard Time UserID: Peanut Profile ID: Total sheets: 2 Sheets plotted: 1 Number of errors: 3 Number of warnings: 0
- Highlight
- Email to a Friend
PMP error.
If at any time you edited the list of available sheet sizes or you created a unique sheet size,
a PMP file is generated of the same name as the PC3 file. When moving (or renaming) the
PC3 file from one profile to another or to another workstation/user, one will get the PMP error.
Best thing to do is to leave well enough alone regarding tailoring the sheet sizes.
Start AutoCAD.
Command OPTIONS.
"Files" tab.
Expand "Printer Support File Path".
Expand "Printer Description File Search Path".
Take note.
Start your favorite file manager (not IE).
Verify the path noted above is there.
Verify the file inside has the same name as the PC3 file.
If not, do this:
Redefine the path to the desired PMP file by first highlighting the path, then select "Browse"
inside the OPTIONS dialog.
Or this:
Command PLOT.
Select the desired PC3 file.
Select the "Properties" button next to that drop down. A dialog will appear.
Redefine your custom sheet size here (or remove the one that has been defined).
Select the "Save As..." button.
Select the OK button.
-OR- Start Over:
Select the desired printer driver.
Select the "Properties" button.
Do what you need to do to create the PC3 file except custom sheet sizes.
Save as button.
OK button.
- Highlight
- Email to a Friend
A possible simpler solution is to reset your settings to default. This can be done by closing AutoCAD, going to windows Start button > All Programs > Autodesk > AutoCAD 2013 - English > Reset settings to default. You will be asked if you want to backup your settings, if you choose yes you will be asked to where to save a zip file to. It wil then begin to start AutoCAD at which point you will get a message saying configuring AutoCAD...
If this produces any errors then I recommend a re-install, unless of course you have student restrictions on your computer ![]()
- Highlight
- Email to a Friend
I have tried all of the solutions that you guys have given me and nothing has worked.
Can someone just export to a PDF so I can email it to my boss.
- Highlight
- Email to a Friend
Ok, find attached the PDF, but as I don't have the sheet-set-infos the fields are empty/not filled.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
