• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Distinguished Contributor
    jz4all
    Accepted Solution
    How to bring jpeg logo on machine in 3D AutoCAD?
    184 Views, 5 Replies
    01-27-2013 11:59 PM
    hi,
    In 3D drawing, how can I bring (or paste) a logo (JPEG format) on equipment .  For instance logo of a company on a machine. How to do that in AutoCAD not Inventor.
    Please use plain text.
    *Expert Elite*
    Re: How to bring jpeg logo on machine in 3D AutoCAD?
    01-28-2013 12:52 AM in reply to: jz4all
    You can use command _IMAGE (looks similar to _XREF) and place the image within your drawing.
    You can use the _RENDER-functionality, in that case create a meterial using that logo-image as texture map (maybe as bump map too) and assign that material to the logo-plate in your 3D-geometry.
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    jz4all
    01-29-2013 04:54 AM in reply to: alfred.neswadba
    Hi
    Thank you for your response.
    I tried but it doesn't work. the image stays separate from the equipment.In Inventor it is easyer (or because I don't know how to do it in AutoCAD) and the logo image becomes part of the equipment, even it follows the topography or profile of the equipment.
    I'll be greatful if you know in steps how to do it in AutoCAD.
    Jaf
    *Expert Elite*
    01-29-2013 07:29 AM in reply to: jz4all
    Do you mean that if you move your model then your image should move too?
    It does ... if you use the way with material and mapping
    it does not if you use the way with command _IMAGE, then you have to move the image if you move the model (or you create a block that contains model and image).
    - alfred -
    Alfred NESWADBA
    Product Support
    01-30-2013 06:34 AM in reply to: jz4all
    Hi Jaf,
    Have you tried creating a new material as suggested?
    http://exchange.autodesk.com/autocad/enu/online-help/browse#WS1a9193826455f5ff-316fd70e123dece8002-5...
    Cheers,
    Luciane
    Luciane Conceição
    Product Support Specialist
    Autodesk, Inc.
    jz4all
    01-31-2013 04:52 AM in reply to: jz4all
    Thanks a lot.
    Jaf
