• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2013/2014 DWG Format
    New Member
    Help with ShapeFiles!
    252 Views, 4 Replies
    10-05-2012 07:22 AM
    I have a data set including .shx .shp .prj and .dbf files each named the same for landuse, rail, road, etc for a single city. How can I open these files to export a simple line drawing for use in a thesis project as a map. (see files attached)
    Any help would be much appreciated as I have never worked with these files before!
    Please use plain text.
    New Member
    Re: Help with ShapeFiles!
    10-05-2012 08:07 AM in reply to: acole91688
    i think we have the same problem ^^
    just one over you
    10-05-2012 10:10 AM in reply to: b.kre
    10-05-2012 10:42 PM in reply to: acole91688
    If you have Map3D use command _MAPIMPORT to get the shape-content imported into your drawing and converted to AutoCAD geometry-types ... or use _DATACONNECT to get the shape-data referenced/visualized in your current drawing.
    Find attached a drawing, but take care of projectionsystem and units for you!
    - alfred -
    Alfred NESWADBA
    Valued Mentor
    TerryDotson
    10-06-2012 05:28 PM in reply to: acole91688
    This dataset is in WGS84 (Lat/Long) coordinates centered about Lon 78.0°, Lat 27.2° which hits in the ocean east of Longyearbyen ?  I have attached the drawing in the lat/lon coordinates.
