• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2013/2014 DWG Format
    Active Member
    Accepted Solution
    HP T2300 Plotter
    278 Views, 2 Replies
    09-19-2012 08:19 AM
    Has anyone else had this problem.  I upgraded to AutoCAD 2013 from 2012 and now when I try and print to our HP Designjet T2300 plotter it prints in the lower corner of the page on a 36"x24" landscape page full size just only 24" wide and down 12".  I am just starting to try and figure out what the problem might be.  I worked around it by printing in 2012 which works just fine.
    Any help would be great.
    Steve
    Please use plain text.
    *Pro
    Re: HP T2300 Plotter
    09-19-2012 01:02 PM in reply to: ssmith
    Steve
    I had a similar pproblem (not exactly but similar) and the solution was to go to HP website and locate, download and install the HP universal printer/plotter driver.
    Worked for me.  YMMV
    Make a restore point before installing the new driver.  If it doesn't work, restore to the restore point you made before you installed the driver.
    DJ
    Active Member
    09-19-2012 01:08 PM in reply to: drjohn
    Thanks DJ I'll give that a try.
