AutoCAD 2013/2014 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
HATCH TRANSPAREN CY
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is it possible to bring hatch aboe all the other objects and cover everything there is below? Even if I go from hatch edit to draw order and bring it to fornt the elements below hatch are still visible also transparency is "by layer" and is set to 0
Re: HATCH TRANSPAREN CY
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I think the matter is to catch all the other objects and send them to back.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
No I still do not get the result I want. I can still see objects below hatch
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is the hatch a Solid, or is it a pattern? Placed in Paperspace or modelspace?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
my hatch is pattern and even though I am not sure what you are asking probably is placed on modelspace
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
if you hatch is a pttern, rather than a solid, then it consists of lines and dashes. Anything underneath the hatch will show up between the spaces. It's rather unavoidable.
What you _could_ do, is use two hatch patterns - one a solid set to True Color 255,255,255 , and the other your pattern hatch, Escher or whatever. Use draworder to place the Solid hatch over everything else, but under the the pattern hatch.
The solid hatch will plot white, effectivly hiding everything underneath, while the pattern hatch on top will plot as it's supposed to.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Or use a hatch with a background color.
