While working with Solids, some times parts that are not United appear out of place, and on the place it was or it should be, appears like a Ghost image in dashed lines. How to solve this problem ? In the attachement a leaf spring with two clips.
Noting that Autodesk is now aware of this issue, look the 4th message in the link below.
Additionally, you may want to add your message/drawing to that topic to help them further determine the cause.
http://forums.autodesk.com/t5/AutoCAD-2013-2014-DWG-Format/Floating-Moving-Parts/td-p/4296789
