• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    File tab makes Acad freeze
    235 Views, 4 Replies
    10-09-2012 10:14 AM
    Hi!
    I'm using Acad 2013, SP1 installed.  When I try to clic on the file tab, Acad freeze! Tried a repair, a reinstall and still with the same issue.
    Do I have to complete a full desinatall / reinstall? I would like to avoid it.
    Any clue?
    Please use plain text.
    Re: File tab makes Acad freeze
    10-12-2012 12:17 AM in reply to: mgbelectrique
    There is an update 1.1 available, the "old one/SP 1" was retired.
    Do you have a screenshot to upload? I don't have a "file tab" in AutoCAD 2013.
    >> Acad freeze
    For ever or is it just a few seconds (I saw sometimes a freezing of about 20-30 seconds, thinking about any wrong path-settings or something like that, but not reproducable yet).
    - alfred -
    Alfred NESWADBA
    10-12-2012 01:01 AM in reply to: mgbelectrique
    Do you mean the pulldown menu "File"? (will only appear when MENUBAR is set to one)
    If so ==> yes, clicking on this menu-item needs some seconds to open it, I can reproduce that (but it does not hangup forever). I found out that the time to verify the recently-file-list needs a lot of time.
    If you set the recently-files to show in that menu-part to a lower value (and restart AutoCAD) the "File"-pulldown menu opens much faster. To set with command _OPTIONS ==> tab "Open and Save":
    BTW: using the new "big-A"-menu is much faster and does not depend on the number of recent-files to show.
    - alfred -
    Alfred NESWADBA
    pendean
    10-12-2012 05:26 AM in reply to: mgbelectrique
    Are you using Windows 7? Turn off it's Aero Theme. Whether you do or not, also change R2013's hardware acceleration from what you have it now (3DCONFIG command) and see if that helps.
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    10-12-2012 05:32 AM in reply to: pendean
    Thank you guys!
    We encountered difficulties with our Symantec, and I don't know why (don't ask me lol), this was the source of the problem ?!?!  Now my CAD runs perfectly!
    Thanks!
