AutoCAD 2013/2014 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Fatal Error e1a2ad73h
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
New week and fresh error from lovely Autocad 2013. I'm sure that it was working when I shut the computer on last friday. Today it does not. Please help, it doesn't even start.
FATAL ERROR: Unhandled acces Violation Reading 0x0000 Exception at e1a2ad73h
Re: Fatal Error e1a2ad73h
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If you mean "AutoCAD does not start" and not something like a specific command "does not start" that you may have a problem with your profile.
If you have not made to much customizations the easiest way is to go to the Windows-Startmenu ==> to the section of Autodesk ==> AutoCAD 2013 and there you find an app for resetting your profile. Let's know if it starts then.
Good luck, - alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
thank you very much alfred; it worked.
the reason was disabiling infocenter from windows registery, I found; autocad is overreacting to it somehow.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
How did you disable InfoCenter from the Registry? I have also done this, but have not had problems with AutoCAD starting up.
I disabled it by navigating to:
HKEY_CURRENT_USER › Software › Autodesk › AutoCAD › R18.2 › ACAD-A001:409
And relabeling the entire InfoCenter folder to InfoCenterOFF.
____________________________________________________________________________________________
System specifications: AutoCAD 2014 64-bit, Windows 7 64-bit SP1, Intel Core i7-2600K, AMD FirePro V4900
16GB RAM, Crucial M4 SSD, 3 Dell Monitors (2 30" 2560x1600 & 1 20" 1200x1600)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
As I see your comment, I tried the same in AutoCAD 2012; it works.
But in AutoCAD 2013, it looks like they don't want us to disable InfoCenter. It crushes.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I also have 2013 installed on a test machine with InfoCenter disabled and no problems there either.
But yeah, sorry, my registry is pointing to 2012 on this computer.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Two days of CAD nightmare, and that solved my problem - thank you, Alfred!!
I never would have guessed.
- Dave
For others, here's where I was at:
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I found when disabling InfoCenter (beginning with AutoCAD 2013 products) that 2013 will Fatal Error if you are still logged into Autodesk 360. We have always used AcadInfoCenterOff.msi by Manusoft to achieve this. Once you logout, 2013 opens just fine. I opened a support ticket with Autodesk and they confirmed this behavior and hope to have fixed whenever SP2 is released. Link to AcadInfoCenterOff
