AutoCAD 2013/2014 DWG Format
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
FATAL ERROR While Opening AutoCAD 2013
- Highlight
- Email to a Friend
Dear Autodesk Lovers,
while opening AutoCAD 2013 on my laptop (Windows 7 Home Premium, 64bit, 8gb, nVIDIA GTX660M 2GB, Intel i5-3210M Processor 3M Cache, 2.50 GHz) it showed
FATAL ERROR: Unhandled Access Violation Reading 0xffffffff Exception at f73b0004h
I was using AutoCAD 2013 before without any problems, it just suddenly started to show this Error Message and now I can't even run the program - shows in the opening. I can't handle with this problem. Is there any advice from any of you? I tried to reinstall, uninstall and then installed again and it still shows the same...
Thanks a lot for any advice!
Appreciate
Re: FATAL ERROR While Opening AutoCAD 2013
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
i faced with autodesk fatal error Exception at f3167ec2h, what should i do ? i always aperas when im trying to lounch autocad 2013. And no maitenance updates helped me so far as well as deleting all the autocad files and instaling it new. . .
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
Dean is right, you will get faster responses in that forum. Typically though, I will do a search thru the forums for misplaced posts.
That being said, most exception errors are caused either by a malware virus or a problem with the .NET Framework. You might run a full virus scan after updating your definitions and then run the .NET cleaner and reinstall the Framework fresh. Repair AutoCAD and see if it helps.
.NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensi
Good Luck!
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
