• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2013/2014 DWG Format
    Distinguished Contributor
    FATAL ERROR 5e2ead66h
    568 Views, 6 Replies
    04-20-2012 02:32 AM
    Why this fatal error for me
    how to over come/ adjust it
    Please use plain text.
    Re: FATAL ERROR 5e2ead66h
    04-20-2012 03:14 AM in reply to: arshadmirza786
    the first important point is: When do you get this message? When installing the software, when starting AutoCAD or sometimes while working with it (then what command raises this exception).
    - alfred -
    Alfred NESWADBA
    04-20-2012 03:21 AM in reply to: alfred.neswadba
    oftenly during working on dwgs and some time at CLOSEing a file
    04-20-2012 04:03 AM in reply to: arshadmirza786
    try to do more often run the command _AUDIT, so you check the drawings you are working on.
    If you see some commands raising up the exception more often, then let us know what command(s) these are.
    If there are specific drawings, do a _WBLOCK and create new drawings based on the current one, go on working with the new drawings and try to verify that the exceptions are then gone (hopefully).
    HTH, - alfred -
    Alfred NESWADBA
    DarrenP
    04-20-2012 07:31 AM in reply to: alfred.neswadba
    to me that looks like a windows 8 windows message box
    is that what your running on?
    05-03-2012 03:33 AM in reply to: DarrenP
    Yes Iam using windows8 cp
    pendean
    05-03-2012 05:08 AM in reply to: arshadmirza786
    Sorry, you are out of luck for a resolution, Win8 preview versions are not supported at this time.
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
