• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    New Member
    Exploding AECC General Label Segments?
    80 Views, 1 Replies
    08-30-2012 09:05 AM
    I have received a Civil file with AECC Labels (they are Countour numbers) and I'm trying to either explode them or convert them to text objects in order to print.
    For some reason, when I explode them they dissappear completely and I have to undo 3-4X to get them back, undoing previous commands in the process. I can't seem to edit them otherwise. The reason I'm exploding them is because CAD is not seeing these objects when plotting.
    Does anyone have a lisp routine or any ideas to help me convert or modify the AECC Labels?
    Thanks!
    -j
    Please use plain text.
    *Expert Elite*
    pendean
    Re: Exploding AECC General Label Segments?
    08-30-2012 11:05 AM in reply to: jaydub720
    1.Ask the recipient to "export to AutoCAD" for you.
    2. You can try it: -EXPORTTOAUTOCAD command (there is a dash in the name) and aim for R14.
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
