AutoCAD 2013/2014 DWG Format
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Error 1325 on first startup
- Highlight
- Email to a Friend
I get the following error message when I try to start AutoCAD 2013 as a user.
Error 1325. 'username' is not a valid short file name.
It runs fine as Administrator.
We are on a domain with roaming profiles.
Windows 7 64 bit.
Any suggestions??
Re: Error 1325 on first startup
- Highlight
- Email to a Friend
is it the first time you start AutoCAD with your account?
If you look into the folder C:\USERS ==> do you see your account-name here? Do you have full access-rights within your folder?
Some reports out in the www say you have to update the "Windows Installer" but I would first as the admin, if you can have (for a short test-time) full local admin-rights, then also turn off UAC and try again.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
- Highlight
- Email to a Friend
Hopefully will have time next week to try "full local admin rights". Will see what happens then. Thanks.
- Highlight
- Email to a Friend
We are now seeing the same thing on our users. We have the same setup as you, except we are using folder redirection rather than roaming profiles. Did you ever find a solution to this?
- Highlight
- Email to a Friend
Try the following tip:
http://www.cadforum.cz/cadforum_en/msi-error-1325-
Vladimir Michl, www.cadstudio.cz
- Highlight
- Email to a Friend
Sorry, no we havn't yet found a workable solution. Currently we are still using 2012.
sundermannc wrote:We are now seeing the same thing on our users. We have the same setup as you, except we are using folder redirection rather than roaming profiles. Did you ever find a solution to this?
- Highlight
- Email to a Friend
vmichl wrote:Try the following tip:
username-is-not-a-valid-short-file-name-tip6686
We are certainly going to look into this as an option.
- Highlight
- Email to a Friend
Just to update future readers of this thread, this solution did work for me. Thank you!
- Highlight
- Email to a Friend
Finally got time to try this and it was successful, thanks very much. ![]()
