• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Osunlade
    Enhanced Attribute Editor
    289 Views, 2 Replies
    11-15-2012 06:44 AM
    When do I have to enter EATTEDIT in the command line to enter the attribute editor facility. I used to double click on the block to do this. When I double click to block, the command line displays 'ampoweredit'
    Please use plain text.
    cbenner
    Re: Enhanced Attribute Editor
    11-15-2012 07:49 AM in reply to: Osunlade
    In your options menu, check on the User Preferences Tab, to see if Double Clikc editing is checked.  Not sure if this is it, but might be one thing to look at.
    ChrisB
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
    Distinguished Mentor
    11-15-2012 08:49 AM in reply to: Osunlade
    I'm pretty sure AMPOWEREDIT is a routine that comes with the Mechanical product.  You might try asking in that DG.
