• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Active Contributor
    Disable Autodesk 360
    2810 Views, 5 Replies
    05-24-2012 05:47 AM
    Does anyone know if there is a registry setting (or some othere way) to disable Autodesk 360.  My users have no reason to use this feature and I don't want them wasting time with it.
    Please use plain text.
    rkmcswain
    Re: Disable Autodesk 360
    05-24-2012 06:39 AM in reply to: smiddleton
    Interestingly enough, you can uncheck this feature during an install, or later using "Add/Remove" features, but even after I removed it - I don't see any change - it is still present in the Open dialog, in the Infocenter, and in the Options dialog. Obviously a bug or someone mistakenly listed it as a removeable feature and it isn't.
    The Autodesk 360 FAQ specifically says you cannot uninstall "Autodesk Sync", a component of 360. Not sure if they mean the whole 360 component or not.
    pendean
    05-24-2012 10:20 AM in reply to: rkmcswain
    As a test, I have turned off the "ADSync" and "AcCloudManager" in Windows from starting with Windows, and turned off the 'enable" and "sync" cloud features in OPTIONS. Not seeing a way to hide it all from view though either.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    05-25-2012 11:15 AM in reply to: pendean
    Hello Dean,
    Could you please give more detail on how you turned off ADSync and AcCloudManager in Windows from starting in Windows.  I'd like to do the same thing and don't know how to do this.
    Thank you,
    Steve
    Product Support
    Mlgolf
    07-12-2012 02:17 PM in reply to: smiddleton
    Hi smiddleton,
    I accidentally seen this post, and thought this may help.
    Please let us know if it did.
    Kind Regards,
    Martin Langolf
    Product Support Specialist
    pendean
    07-13-2012 05:22 AM in reply to: SteveChestnut
    You can uninstall Autodesk Sync in Using Windows' own Uninstall feature.
    I used a freeware called CCLEANER for the test above.
