• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Valued Contributor
    Dimension text disappearing when selecting dimensions
    255 Views, 6 Replies
    11-15-2012 07:14 AM
    In AutoCAD 2013, when I try to select a dimension object for moving, erasing, &c, the text disappears. Any idea how to get it to stay displayed?  Seems to just be when using AutoCAD 2013.
    Please use plain text.
    *Expert Elite*
    Re: Dimension text disappearing when selecting dimensions
    11-15-2012 12:42 PM in reply to: ajohnson
    can you upload that drawing (at least these dimension and it's base object) so we also can try to select the object?
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Valued Contributor
    11-15-2012 01:12 PM in reply to: alfred.neswadba
    Here's a drawing file.
    I think I figured out the cause (but not the soluion, well maybe I've got one). When textmasking (Text Fill Color) is set to background, the text disappears. This could be a change from 2012 to 2013 or it could be because I have an older graphics card.
    I checked on another machine with a different graphics card and the text doesn't disappear.
    I need a new machine anyway.  Hey Boss....
    *Expert Elite*
    11-15-2012 01:30 PM in reply to: ajohnson
    same to me, opening your drawing and selecting any of the dimension does not result in text disappearing.
    The difference may be that I have installed SP1.1, have you installed it also?
    And yes, it may be the graphics card or driver, to make it easier for your gc try if the same issue araises if you have disabled the hardware acceleration (command _3DCONFIG ==> manual tune)
    - alfred -
    Alfred NESWADBA
    Valued Contributor
    11-15-2012 01:40 PM in reply to: alfred.neswadba
    I did try with and without the hardware acceleration.  Same thing.
    Probably time to go talk to the boss.  He has the same graphics card as I do, but 2013 isn't offical in the office yet.
    *Expert Elite*
    11-15-2012 02:20 PM in reply to: ajohnson
    just to make sure: have you installed SP1.1?
    For you and your boss if SP1.1 repairs the issue: better then investing into a new computer maybe to invest into your salary :smileywink:
    - alfred -
    Alfred NESWADBA
    Valued Contributor
    11-15-2012 02:27 PM in reply to: alfred.neswadba
    I wish.
    Anyway SP1.1 is on the machine.
