• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2013/2014 DWG Format
    Defpoints
    287 Views, 15 Replies
    11-09-2012 01:44 PM
    How do I turn off the defpoints layer so it does not appear when i use the dimension tool while editing a block.  I simply want to turn it off so the layer doesn't appear in the layer manager.
    Please use plain text.
    pendean
    Re: Defpoints
    11-10-2012 08:03 AM in reply to: jrittenhouse
    You can't get rid of 0 or defpoints layer or a few other 'system' layers that come along as you use commands and features that need them.
    What exactly are you having trouble with? perhaps there is a better fix.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Re: Defpoints
    11-12-2012 08:52 AM in reply to: pendean
    is there a way to prevent the layer from appearing?  the project im working is specific about what layers can or can't be on the dwg.
    *Pro
    Re: Defpoints
    11-12-2012 09:34 AM in reply to: jrittenhouse
    Defpoints can be FROZEN or TURNED OFF but as Dean noted it cannot be deleted.
    DJ
    Re: Defpoints
    11-12-2012 09:41 AM in reply to: drjohn
    That is incorrect.  Defpoints inherits its screen display from layer 0.  The only way to turn off or freeze defpoints is to freeze or turn off layer 0, which is HIGHLY discouraged except for short term changes.
    Get used to defpoints being on.  Any layer standard that wants it off should be discarded and reworked.  Dimensions depend on defpoints.  Defpoints won't plot so what is the real problem?
    *Pro
    Re: Defpoints
    11-12-2012 10:05 AM in reply to: dbroad
    Strange.  Maybe I don't get it.  I can go into LAYER MANAGER and turn off DEFPOINTS  or freeze DEFPOINTS and it doesn't display.  It is still in the LAYER MANAGER but not displayed nor printed yet layer 0 (zero) is still the same as it was before the DEFPOINTS layer was turned off or frozen..
    I think one of us is thinking reversed.
    DJ
    Re: Defpoints
    11-12-2012 12:17 PM in reply to: drjohn
    Defpoints is quirky.  Both of us are right.  Points drawn on layer defpoints take their display color and display from defpoints.  You need to freezeor turn off  layer 0 in order to make points drawn on layer defpoints disappear.  Other objects will recognize the color and display settings of defpoints.
    Points in dimensions display according to the layer of the dimension.  I have run into exceptions where the dimension layer needed to be frozen to stop the display of the defpoints. (I think).
    Valued Mentor
    TrevN
    Re: Defpoints
    11-14-2012 07:49 AM in reply to: dbroad
    Well I never have defpoints layer. I delete it straight away and have never had a problem.
    (As yes you can delete it using laydel command.)
    *Pro
    Re: Defpoints
    11-14-2012 08:03 AM in reply to: TrevN
    You must not use dimensions in your type of work.
    I can delete Defpoints layer with laydel also.
    As soon as I strike a dim it's back again.  I delete it with laydel again and the dims stay associated.  I strike another dim and the defpoints layer is back again .... ad nauseum
    What's your magic for making it stay gone?
    DJ
    Valued Mentor
    TrevN
    Re: Defpoints
    11-14-2012 08:07 AM in reply to: drjohn
    No magic!
    Options setting have all new dims associated.
    Just delete it when ever it appears, hey presto, gone!
