• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    DRAG & DROM is not working on AutoCad 2013
    404 Views, 5 Replies
    04-22-2012 10:32 PM
    I used to drag and drom an image from my desktop in a drawign in 2012 version.
    Now is not working and I get the following
    Any ideas?
    Thanks in advance
    Stelios
    Please use plain text.
    Re: DRAG & DROM is not working on AutoCad 2013
    04-23-2012 01:20 AM in reply to: xantzakoss
    what image-format did you try, I checked now TIF and PNG, both work well.
    Does the command _IMAGE work with that file?
    I have tried it with AutoCAD 2013 German and Civil 3D 2013 German.
    - alfred -
    Alfred NESWADBA
    04-23-2012 05:27 AM in reply to: alfred.neswadba
    The files that I am using are tiff and I am using Autodes Architectural Desktop.
    04-23-2012 07:54 AM in reply to: xantzakoss
    ...and my second question?
    - alfred -
    Alfred NESWADBA
    pendean
    04-23-2012 10:05 AM in reply to: xantzakoss
    What format TIFF files?  Can you insert them using the Reference palette at all?
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    rkmcswain
    04-27-2012 01:49 PM in reply to: xantzakoss
    The drag & drop functionality appears to call the (imagefile) lisp function which is defined in Acad2013doc.lsp.
    Paste this to the command line:
    (startapp "notepad" (findfile "acad2013doc.lsp"))
    If a file does not open in Notepad, then your support file search paths are hosed more than likely.
    (Image format is not an issue at this point, since the lisp function isn't even getting to the point of firing that up)
