• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    New Member
    Current layer problem - autocad 2013
    229 Views, 3 Replies
    01-16-2013 08:12 AM
    When I set a layer as current, every object or line I select in the drawing appear to be on that layer in the toolbar. Although in the properties toolbox, I see that the line I selected is still on the right layer.
    I can't work in paperspace either, when I freeze a layer it freezes all objects. It seems like whenever I give a different layer to an object, it attributes to all object that same layer.
    When I open the same drawing in acad 2008, everything is ok, the objects have the proper layers.
    Is there a command for that or it's an acad 2013 problem?
    Please use plain text.
    Patchy
    Re: Current layer problem - autocad 2013
    01-16-2013 08:18 AM in reply to: Janiela
    Are you talking about PICKFIRST variable? if it's zero change it to 1
    New Member
    01-16-2013 09:06 AM in reply to: Patchy
    Yesssss! It worked! Thank you!!!!
    Active Member
    prem.savio
    01-22-2013 10:46 PM in reply to: Patchy
    Worked like a charm.
    Thank you
