• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Member
    Create a 3D solid object
    217 Views, 6 Replies
    01-23-2013 09:19 AM
    Hi.
    Can anyone help me creating this object in 3D solid? The circles have the same height in both edges.
    Thanks.
    Please use plain text.
    Re: Create a 3D solid object
    01-23-2013 09:20 AM in reply to: miguelsilva.arq
    Loft.
    Attach the dwg file of what you have attempted so far.
    Member
    01-23-2013 09:27 AM in reply to: JDMather
    Here it is.
    Member
    01-23-2013 09:54 AM in reply to: JDMather
    Or this imported from google sketchu.
    Valued Contributor
    Anthonius
    01-23-2013 01:18 PM in reply to: miguelsilva.arq
    Hello!
    Use the "LOFT" command.
    Type LOFT
    Choose one arc-polyline, then choose the other, then hit ENTER.
    It'll make a 3D solid that you're looking for.
    Enjoy!
    AutoCAD 2013 64 bit
    AutoCAD Architecture 2013 64 bit
    Revit Architecture 2013
    Windows 7
    Have a good time, all the time.
    Valued Contributor
    Anthonius
    01-23-2013 04:05 PM in reply to: Anthonius
    Here's a short tutorial I made regarding your drawing and the "LOFT" command.
    Chronicle - Loft Command
    AutoCAD 2013 64 bit
    Windows 7
    Member
    01-24-2013 01:24 AM in reply to: Anthonius
    Thank you very much! Very useful.
