• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Active Member
    Re: CUI Unhandled exception has occurred
    04-17-2012 09:42 AM in reply to: steven.boyd
    Do not Anchor it either
    Please use plain text.
    Product Support
    04-17-2012 11:35 AM in reply to: steven.boyd
    I cannot reproduce the error on my system, even with hjouzou's CUIX loaded. I wonder if this is indeed an issue with migrated settings coming from too distant of a version of AutoCAD, having some data corruption, acquiring some data corruption during the migration process, or having been migrated through too many versions of AutoCAD over the years (er, I guess some of those overlap each other).
    Can you guys try resetting AutoCAD to defaults or test a new user account to see if the problem still occurs?
    Bryce Thelin
    Product Support
    Member
    04-17-2012 12:32 PM in reply to: steven.boyd
    Yes Steven, this is exactly the thing I am talking about and your solution is exactly the one I did to solve it! Yet Autodesk have to find a solution for it because it looks like a silly bug! Whenever you assign the Quickcalculator Pallet Orientation "Right" or "Left" in the CUI interface, save the CUI and close AutoCAD, the next time you open it you will get that error! And when you press continue, you will see the Quickcalculator pallet floating in the middle of the screen!
    Autodesk guys..Any clues?
    Active Member
    04-17-2012 02:20 PM in reply to: bryce.thelin
    Bryce,
    I reset to default setting and anchored the calculator to the right, closed & i still got the error. I've reproduced this error with 3 other users in our office. None of them use the calculator so i don't see the migration process affecting their calculator. It only happened when i added the calculator & anchored it...
    Product Support
    Re: CUI Unhandled exception has occured
    04-17-2012 03:22 PM in reply to: hjouzou
    Finally, I managed to reproduce the error on my laptop. It won't happen on my desktop system though, for some reason. I also found a report logged with our development team on the problem during beta testing of AutoCAD 2013. It looks like something sifted through to the release version. So it's on the to-do list to be fixed, but no ETA.
    Bryce Thelin
    Product Support
    New Member
    05-12-2012 02:55 AM in reply to: bryce.thelin
    I had exactly the same error message. I have found a simple workaround; at least it resolved the issue on both my Desktop and Laptop. Open Quick Calc, there is a ‘More’ button to the right of where it says ‘Basic Calculator Mode, Click this to show the basic number pad. Now you can dock and anchor the Quick Calc window. Close and reopen the program, hopefully you should now not get the error message.
    It appears that not having the number pad expanded ONLY when the window is docked and anchored causes the error message.
    Hope this helps!
    Product Support
    05-14-2012 09:03 AM in reply to: hjouzou
    Looks like I get the error either way, number pad showing or not. :smileysad:
    Bryce Thelin
    Product Support
