• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Distinguished Contributor
    CUI Customize Causes Crash
    252 Views, 4 Replies
    06-26-2012 06:05 AM
    AutoCAD 2013 crashes each time I attempt to invoke the CUI customize command from the workspace pulldown.
    Thanks for your comments,
    Clint Hill
    Please use plain text.
    Valued Mentor
    TerryDotson
    Re: CUI Customize Causes Crash
    06-27-2012 09:01 AM in reply to: chillme1
    I believe the CUI command is .NET based, as are most of the functions in ToolPac.  Perhaps your .NET Framework 4 is corrupt and needs to be reinstalled?
    06-27-2012 09:10 AM in reply to: TerryDotson
    Having recently re-installed both the previous release of AutoCAD 2012 as well as your excellent ToolPac utilities, I had no such errors nor crashes result from neither the CUI manipulation nor from invoking any ToolPac commands.
    It appears that there may be other causes that affecting the stability of the 2013 release.
    Clint Hill
    Valued Mentor
    TerryDotson
    06-27-2012 09:41 AM in reply to: chillme1
    Both AutoCAD 2013 and ToolPac 14.1 running on it uses Framework 4 as opposed to previous versions using previous versions of the framework.  So a corrupt Framework 4 wouldn't have affected 2012/TP13, etc.
    07-03-2012 06:53 AM in reply to: TerryDotson
    POSSIBLE CAUSE FOR ISSUE:
    Prior to installing Product Design Suite  Standard 2013, I realized that the new Visual Studio Beta version was installed and may have contributed to the instability with AutoCAD 2013. I have now uninstalled the VS Beta.
    I have been encouraged by the timeliness and substances of the responses from Autodesk support staff and other developers and users here.
    Due to the excellent workarounds and responses given, I am now feeling comfortable enough to re-install AutoCAD 2013 and, as time allows, run the program.
    However, AutoCAD 2012 and other 2012 products will be used for production purposes at this time.
    Clint Hill
