AutoCAD 2013/2014 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Blocks have multiple scales attached
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi
I'm working in 2013 and when I insert an annotative block at one scale say 1:10 because that's what it needs to be at, than within in the same drawing file I'll add another block but need a different scale say 1:50, than when I go back to the first block and click on it to edit it, it will have both scales attached to it and sort of blow up to show both scales until you exit out of it than it'll go back to normal.
Please help it's driving my co-workers crazy!
Re: Blocks have multiple scales attached
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
There are 2 buttons at the bottom of the screen (annoallvisible and annoautoscale). Turn off annoautoscale and you will not be adding annotation scales to all of your objects whenever you change scales.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
What does the button look like I've checked all the ones along the bottom and don't see annoautoscale, but if I type that in the setting is at -4
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
PLEASE check out the site below. Thank you.
http://www.grammar-monster.com/easily_confused/tha
One shouldn't walk through life blindly without receiving some help now and THEN. :-)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks Steve...
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You're welcome and I hope that was sincere. I would certainly appreciate the same. Seriously!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm not sure what relevance Steve's contribution has but if you hit F1 at the annoautoscale prompt, help will tell you everything else you need to know. If you don't see the buttons on your status bar, right click and add them.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm not entirely sure either, but to each their own.
Thanks very much!
