AutoCAD 2013/2014 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Best method for creating and deforming an assembly of ultra-thin layers
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I want to make 3D assemblies of very thin layers (the layers have 1000000:1 lateral to depth dimensions) in AutoCAD. Currently I make them in PTC Creo, but I would like to move to using AutoCAD instead.
What is the best method to do this? Specifially, how can I extrude multiple (6-8) ultra-thin layers individually, then join them in an assembly which I can bend and flex to make 3D surfaces? I have attached a Keyshot render of a design I did in Creo. I would like to make the exact same structure in AutoCAD. The design is 6 layers stacked on top of each other, joined as one part, than manipulated into a complex, 3D shape.
Also, is AutoCAD the best Autodesk software to do this? I have access to the student versions of the Autodesk software if it makes a differene.
Cheers,
Jonathan
Re: Best method for creating and deforming an assembly of ultra-thin layers
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
an additional question: do you need that for visualisation reasons? Or where do you get the bending-rules/formulas/base-geometry/... from?
- alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The bending rules in the picture are two 20 degree twists on two different datum planes done in Creo, and are purely aesthetic.
I would like the ability to manipulate the film by rotating or bending about datum planes or axis, or something that will give that effect.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
AutoCAD probably isn't the best tool for this. Duck into the Inventor forum - if thats not appropriate I'm sure they can give you a better idea of what will be. You might end up using Inventor or a similar product to do the design, then something like Maya or 3DSMAX to do the twisting.
Adopt. Adapt. Overcome. Or be overcome.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
tha tlooks almost like flexible semiconductor circuitry. hmmm...
i wonder what our R&D guys use. if it werent hush hush, i'm sure they'd tell me.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
dgorsman: Thanks, I took your advice and I'm learning Inventor now, we'll see how it goes.
YOUNGBL00D: Good guess, it's a multi-plexed array of organic transistors. Any chance you can find out what your guys use for CAD?
