• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Active Member
    Base view layer properties retention
    71 Views, 2 Replies
    12-19-2012 06:20 AM
    I was woundering if there was a way to retain original object layer properties when in base view.  IE I have 4 layers, each with a different color.  I would like to create a beaseview, and still keep the object layer colors.  Is there a work around for this?  Or should I just do an elivation and work through VP's?  Any help is appriciated.
    Please use plain text.
    GrantsPirate
    Re: Base view layer properties retention
    12-19-2012 07:15 AM in reply to: radioflyer364
    You will get two layers with viewbase, if you need more control then you will have to do it with the other methods.
    Active Member
    01-15-2013 06:07 PM in reply to: GrantsPirate
    That is what I thought. I was really hoping for a secret Baseview layer manager inside the ribbon. Thanks! Richard Palmer Adjunct Professor - AutoCAD University of Cincinnati - CCM (513) 556-3709
