• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Accepted Solution
    Background Mask - Dimensions
    272 Views, 4 Replies
    01-29-2013 04:02 PM
    When I try to apply the background mask while inside the text editor of the dimension the background mask does not apply. However if I right click the dimension -> properites-> text->fill color -> background, it works.
    Am I doing something wrong or do others have this issue?
    Thanks!
    www.HowToEngineer.com
    Please use plain text.
    *Expert Elite*
    pendean
    Re: Background Mask - Dimensions
    01-30-2013 06:11 AM in reply to: RFreund
    Limitations of the text editor in dimensions I believe: wring tool for the object type. It's been around for quite some time.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    01-30-2013 06:18 AM in reply to: pendean
    So is the correct way to mask dimensions using the properites and apply fill color as described above?
    *Expert Elite*
    pendean
    01-30-2013 06:36 AM in reply to: RFreund
    Any method you described here that work are the choices, use set it in your DIMSTYLE as the default (or set an identical DIMSTYLE but with this option selected and change the dimensions as needed).
    Use DIMTFILL and DIMTFILLCLR variablesw if you want to control them in a macro, lisp, or the command line for the active DIMSTYLE.
    05-16-2013 01:45 PM in reply to: RFreund
    This was my question - exactly - and it worked like a charm!  Thanks, Dean
