Everytime I try to use the etransmit command, i get fatal error. This didn't happen with the previous version of autocad, it only started happening once I installed v14.
Ever happened to you?
Solved by kevlor. Go to Solution.
I don't see Civil3D_2014_OE_64Bit_SP1 anywhere on Autodesk website. Can anyone confirm it exists and where to find it?
FYI - I have 6 AutoCAD installs... one of which suffers from Civil OE crashing AutoCAD on etransmit (AutoCAD 2014, SP1). If I uninstall Civil OE, etransmit works fine... reinstall Civil OE, etransmit crashes AutoCAD.
Uninstalling the original Civil 3D OE and then installing the new Civil 3D OE SP1 worked for me.
http://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autocad-civil-2014-ob...
- Rusty
was fixed already....
here...The fix I've made
(defun etransmitFIX (/ exe aecc) (vl-load-com) (if (setq exe (findfile "acad.exe")) (if (setq aecc (findfile (strcat (vl-filename-directory exe) "\\AeccETransmit.dbx"))) (vl-file-rename aecc (strcat aecc ".old")) ) ) )
Thank you...
since last post,..(few years ago) 🙂
we passed on Civil 2017 ...but we now used custom tool to made this steps allowing more options, more faster and work much better than actual e-transmit.
sometime having Programming knowledge help companies to be more productive. 🙂
Can't be more simple then that.
The problem is the cloud.
eTransmite to the desktop and then copy it back to your cloud drive folder 🙂
Enjoy
