AutoCAD 2013/2014 DWG Format
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Autocad 2013 commands stopped working
- Highlight
- Email to a Friend
It started with draworder coming back as unknown command. Then I installed service pack 1.1. NOt cui attribute edit and a bunch of other command have completely stopped working. I've not changed anything in cui in weeks. Everything worked fine yesterday. today everything seems to have gone haywaire.
Someone help please...
Re: Autocad 2013 commands stopped working
- Highlight
- Email to a Friend
Sounds like your EXPRESS is not running
Menuload and load the EXPRESS or type in EXPRESSMENU
- Highlight
- Email to a Friend
Go into Options, to the Files tab, and look under Support File Search Path. Add the following path if it is not there:
C:\program files\autodesk\autocad 2013\support\en-us
Let me know if this helps.
Bryce Thelin
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
I wanted to follow up with you on this discussion thread. Please let me know if any of the above helped. If it did, please click the "Accept as Solution" button. Thank you!
Bryce Thelin
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
Hi Bryce-
Larger issue would be if the program is dumping the file path, why is it doing so?
I've been experiencing many similar issues where all of the 2013 platform products (Autocad, Autocad MEP) randomly dump profiles, won't load lisp, etc. Usually I find that support paths have randomly disappeared from the working support paths table. Sometimes however files won't load even though the support paths indicate they did (sometimes even the APPLOAD dialog indicates they're loaded when they're not... go figure that one). Block libraries go unreferenced, etc.
Our configurations have worked very well (i.e. stable) for 4 years, but with the introduction of 2013, even the 2012 products have the same issues now which really has me puzzled... but since that's the only thing that's changed (adding 2013) to the mix, and the behavior is the same, I have to conclude that they are related or a recent patch to 2012 has introduced the same problems present with 2013.
